Order Farmall Cub Parts Online
? about oil pressure on Cub
Alvin NE WI
06-18-2003 18:48:26
Have finished the job of restoreing the Cub, "49 model. Have had it runing numerious times and didn't really notice or have it running that long at one time. Today with this hot weather I was going to take it for a lenghtly ride. After about a half hour running I looked at oil pressure gauge and it was hardly in the white for normal. Is that common for a Cubor should they have more than that when hot. I got regular gauge, redone the motor except a new oil pump. Will it get better after more hours on the motor. right now I have maybe about 5 hours on the rebuild . My mind doesn't remember what it was years ago when running, got to the time of CRS. Thanks for any information. Alvin
LITTLE RED
06-19-2003 18:43:35
 Re: ? about oil pressure on Cub in reply to Alvin NE WI, 06-18-2003 18:48:26
ALL I CAN TELL YOU IS THE HOTTER IT GETS THE LESS OIL PRESSURE YOUR LIKELY TO HAVE GIONG
BY MY OWN 52 CUB ITS REAL HIGH WHEN COLD BUT AS
IT GETS HOT IT DROPS WAY DOWN TO THE LAST 1\4
OF THE WHITE THATS ALL I CAN TELL YOU DOUG R
