Transmission help!!
Chris P
06-18-2003 19:38:18
Just got my first 1960 cub and ran fine for 1 week and now it will not move! I am able to move from 1st,2nd,3rd,and reverse without using the clutch and no grinding but nothing happens, is it the clutch or hole transmission. (fluid levels are fine)
BOB
06-18-2003 20:32:52
 Re: Transmission help!! in reply to Chris P, 06-18-2003 19:38:18
Chris, sounds like the joint came apart at trans end.bolts to front of trans then goes to the flywheel.put tractor in gear then try starting without cluch depressed,this should try to walk the tractor as starter is running?
gm
06-18-2003 20:07:00
Try the connection between the tranny and the clutch. I am not sure on the cub but there should be an access cover you can remove and perhaps fix it from. -Greg
Chris P
06-18-2003 20:26:34
 Re: Re: Transmission help!! in reply to gm, 06-18-2003 20:07:00
I do think there is an acces from the bottom. will I need to empty the fluid? I know this is a dumb question, just not much of a mechanic.
gm
06-19-2003 14:53:56
 Re: Re: Re: Transmission help!! in reply to Chris P, 06-18-2003 20:26:34
If there is an access panel just for the clutch
housing, you shouldnt need to drain anything. Of course, if you are opening the tranny from the bottom, you will get oil :) -Greg
