Farmall 806 stuck in low range
Bernie Finch
06-20-2003 06:02:57
I have a farmall 806 LP and it is stuck in low range. What do I do??
Mark B
06-20-2003 06:14:04
 Re: farmall 806 stuck in low range in reply to Bernie Finch, 06-20-2003 06:02:57
Down under your feet on the right side you will notice your linkage. Put your transmission in neutral and take a screwdriver and line up the slots on the linkage. This should allow you to return to normal, but you may need to work on your linkage so it wont happen again, I'd say shes getting a little loose. Hope this helps, Mark
