Will IH wide front from M fit H?
26RED
06-20-2003 11:45:25
Will a IH wide front off a 1945 M fit a 1946 H? Or will I need a different front bolster?
Red Rider
06-21-2003 20:47:33
 Re: Will IH wide front from M fit H? in reply to 26RED, 06-20-2003 11:45:25
It depends on what wide front your M has under it. If it has the IH wide front with the tie rods behind the axle, then yes it will fit all except the stay rod ball socket bracket that bolts to the frame behind the axle. If it is the IH wide front that has the tie rods out front then plate that bolts under the bolster will be to wide for the H.
howster mighty
06-20-2003 13:33:19
the m is wider & the holes won't line up but i bet you could make it fit.
