Oil Pan
Scott
06-21-2003 15:01:58
went to change the oil on my 400 today and the bolt pulled out of the pan. Brazed it back in but it continues to weep around the brazing. Anything any one knows of that I can spread inside the pan to stop the leaking?
Thanks for your help!
Scott
06-22-2003 09:16:54
 Re: Oil Pan in reply to Scott, 06-21-2003 15:01:58
Puttied it up with JB weld and that took care of any final weeping.
Thanks for your comments!
Bob in SE Nebraska
06-21-2003 19:35:33
It sounds like you brazed it while the pan was still on the tractor. I would recommend removing it from the tractor and doing the repair. It is probably getting oil on the inside which prevents the brazing from sticking to the pan. Hope this helps, Bob
here, try this
06-21-2003 16:52:32
keep brazing till you get it right
