706D has a Problem
cagle
06-21-2003 17:03:46
My 706D has a problem. If you hit the brake to turn shorter, tractor will stop. It also hesitates when you let out on the clutch. When it stops with the brake, if you rev up the engine it will eventually take hold, but with a jerky motion. It has a TA, and is out on low side. I have a new MCV pump, and have rebuilt the MCV. It was doing this prior the pump and MCV change. What else can it be? Filter has also been changed..
Aces
06-22-2003 17:46:07
 Re: 706D has a Problem in reply to cagle, 06-21-2003 17:03:46
The remote and hitch pump should nor efect the TA brakes or steering. If you have a leak in the TA some place that could cause your problem but it has to be in the TA or MCV some place. If your Hitch and remoye hydraulics work OK then your filter and oil supply should be OK if not maybe the suchion side is leaking.
REDMAN
06-22-2003 09:01:47
DID YOU CHECK THE OTHER PUMP?IT IS ON THE SAME SIDE AS THE MCV RIGHT IN FRONT OF THE AXEL.THAT ONE WILL GO MOST TIMES BEFORE THE MCV PUMP DOES.IT ALSO FEEDS THE MCV PUMP SO IF IT IS OUT AND YOU HIT THE BRAKES IT WILL STARVE THE REST OF THE SYSTEM
