Re: super m meets 12 volts
Paul Janke
06-22-2003 09:22:07
You said you also swapped the plug wires. The plug wires don't care if the juice is from a 6 or 12 or 24 volt coil or from a magneto. I am guessing that one of the plug wires from the truck is bad. Try switching back or use a different one from the truck. I hope this is all it takes.
Steve - IN
06-22-2003 09:47:48
 Re: Re: super m meets 12 volts in reply to Paul Janke, 06-22-2003 09:22:07
Paul,
Good point about the plug wires. The ones in a truck a probably carbon core for radio shielding. The ones in the tractor were probably stranded copper. The truck wires have a lot more resistance and therefore don't make nearly the spark a set of copper wires would. That could the the difference right there.
