IPTO SMTA
Dan
06-22-2003 09:59:59
Pulled the cover off the back yesturday as it seemed to slip some especially when first engaged. Found the nut and lock loose on the pto shaft. Otherwise things didn't look too bad. How much lining is supposed to be on the bands? The brake band still showed some texture and had to high and low spots around, or grooves. The other one showed more wear. I exchanged the brake for the engage band and put them back. Need a new lock nut and seal for the rear though. How much do the bands cost? Is there a source of re lined bands or just through IH?
