1976 IH 140 oil leak
J. Gieger
06-22-2003 13:36:44
My 1976 IH 140 has apparently blown an inner seal of some kind as there is oil dripping from a weep hole on the underside of the differential housing.Any tips,info.or guidance on repairing this would be greatly appreciated,Thanks.
Hugh MacKay
06-22-2003 17:05:12
 Re: 1976 IH 140 oil leak in reply to J. Gieger, 06-22-2003 13:36:44
It sounds like the seal between final drive and transmission-differential case. Are you sure your transmission is not over full of oil? I would check that before doing anything else. These will leak if transmission is overfull.
Phlogiston
06-22-2003 14:55:53
Do you mean the hand hole? If it is coming from there you may have a bad rear main seal. If so, the tractor must be split to fix it.
Phlogiston
J.G.
06-22-2003 16:39:12
 Re: Re: 1976 IH 140 oil leak in reply to Phlogiston, 06-22-2003 14:55:53
No, its not comming from the hand hole in the bell housing but under the differential housing.There's a small hole at the far left end I didnt even know was there before.It's not rusted through or anything,looks like it belongs there.
