New Holland Hayliner 67
Tony
06-22-2003 17:49:52
I recently discovered this NH Hayliner 67 square baler in my grandpa's barn, and everything seems to run smoothly, but I have no idea how to thread the twine....Can anybody tell me where a manual could be online or how to do it by e-mailing me or something?....I'd appreciate it.
hal
06-22-2003 20:32:44
 Re: New Holland Hayliner 67 in reply to Tony, 06-22-2003 17:49:52
what do you need to know. I use a 67 as we speak. Its not hard how to thread the needels. bring the twine thru the back of the holes in the back of the twine box and the twine friction plate then there will be a porcline spool on the angle brace on the hitch tounge then you will bring both twines thru and then underneath each needels there will be seperate porcline spools for each twines then go thru. the eyes of each needel and pull about 3 or 4 feet of twine then trip the bale lenth arm while running let the tying cyle finish then pull on the excess twine out of the knotter and you should be ready to bale hay if everything is working right. if you need more help please e-mail me or call me and I will go more in depth with you hope this helps. Hal PS right now we are up to a**es in hay [about 210 acers]
Farmer Bob
06-22-2003 19:50:44
You can call 1-800-635-4913 and probably get the manual(s) you need.
Tony
06-22-2003 20:10:24
 Re: Re: New Holland Hayliner 67 in reply to Farmer Bob , 06-22-2003 19:50:44
I called New Holland (1-800-635-4913), and unfortunately they do not make an operation manual for this model...only a parts manual. I don't know why that is, but oh well. Thanks anyway.
Doug
08-13-2003 12:51:02
 Re: Re: Re: New Holland Hayliner 67 in reply to Tony, 06-22-2003 20:10:24
I phoned NH to get a manual for this baler also but they said the only manual they have is for a S67. I don't know what the difference is so I ordered one. It was only about 15$ shipping included. Its on back order so I'm looking at a month before I'll get it but will let you know if its the right one or not.
Doug
