What size tires should I put on an Farmall M
Adam R
06-22-2003 19:11:55
I need to put new tires on my M due to a bluge in the side wall, and can't decide if I should put 13.6-38's or 14.9-38's on it. It is a working tractor so authenticity is not a concirn. It also has the standard 12 inch rims. I was just wondering what you guys would recommend. Any help would be greatly appericiated.
Haas
06-23-2003 05:57:52
 Re: What size tires should I put on an Farmall M in reply to Adam R, 06-22-2003 19:11:55
Most Ms have 11 inch rims. I think the best size and most common for the M is the 13.6 X 38.
randy hall
06-22-2003 20:17:36
i'd bet a dollar that your m has eleven inch rims. 13.6 will work the best. 14.9's will be humped up and not wear evenly.
