1946 Farmall B misses after 20 minutes
Mark in Mi.
06-23-2003 08:07:52
Starts and runs fine for about 20 minutes. After 20 minutes starts to miss. Replaced points, condenser, plugs, wires. What could it be? Need help.
Thanks Mark
Question for Farmall Dan
06-23-2003 11:01:14
 Re: 1946 Farmall B misses after 20 minutes in reply to Mark in Mi., 06-23-2003 08:07:52
Dan how do you check for valve lash?
Thanks,
Mark
farmalldan
06-24-2003 09:53:23
 Re: Re: 1946 Farmall B misses after 20 minutes in reply to Question for Farmall Dan, 06-23-2003 11:01:14
Steve pretty well covered it. Set lash with engine hot. I seem to recall that specs for the c113 is 0.014, but you need to confirm that. Memory isn't what it once was. No pointer on crank pulley on A, B, or C. Timing marks are on flywheel. Look through handhole at bottom of flywheel. Pointer is on front cover of bellhousing. Marks are very hard to find and I recommend Steve's procedure for valve lash. Setting ignition timing makes finding the marks mandatory.
Steve - IN
06-23-2003 18:48:32
Mark,
Remove, hood, plugs, and valve cover. Turn engine to TDC or top dead center on #1 cylinder - farthest forward cylinder. At TDC the pulley on the crank should line up with a pointer. If you don't have a mark/pointer, turn the engine with your finger in the spark plug hole until compression starts to blow your finger off the hole. You're close -- now take a drinking straw or equivalent and place into hole and turn engine and watch it ride up. When it starts to go down, you've gone too far, back up and go for the highest point.
When that is done, the two rockers for #1 cylinder should be loose against the valve tops. Slide a feeler gauge in to measure the clearance. Don't have an A spec handy, but an H is .017" hot. Guesstimate .019 or .020 cold. If there's not enough or too much clearance, undo the lock nut on the top of the rocker and turn the screw with a screw driver until the feeler gauges begins to get snug.
Do the other 3 cylinders the same way....
Also check the condensor and the coil, problems with them can produce similar results.
Ben in KY
06-23-2003 10:18:22
Don't forget about the condenser. I one time boungt a coil for the same symptoms and finally fighred out it was the condenser.
farmalldan
06-23-2003 10:12:26
Another item to check is valve lash. Insufficient lash will close down as the engine warms up and prevent valves from closing, resulting in a miss.
John J
06-23-2003 08:24:46
Sounds like the coil is breaking down on it.
