H Throttle Trouble
Ryan
06-23-2003 08:47:58
I've got an H that's giving me problems. With the throttle lever pushed up all the way, the tractor is at idle, but when I pull it back less than half way, it's already at wide open. This makes it very hard to keep the tractor at a speed in between. I don't know a whole lot about it, so any helpfull feedback is greatly appreciated.
Bruce Wa.
06-23-2003 18:08:01
 Re: H Throttle Trouble in reply to Ryan, 06-23-2003 08:47:58
Check the bell crank on top of the engine. If you put it on backwards it will cause this . Ours was this way for years . then i took it apart and found it worked much better when i turned it around.
Ryan
06-23-2003 19:05:57
 Re: Re: H Throttle Trouble in reply to Bruce Wa. , 06-23-2003 18:08:01
I don't mean to sound dumb, but I'm not sure what you mean by a bell crank.
Wayne Swenson
06-23-2003 21:17:07
 Re: Re: Re: H Throttle Trouble in reply to Ryan, 06-23-2003 19:05:57
It is the part that connects the upper rod from the throttle lever to the lower rod that goes to the governor.
Wayne Swenson
06-23-2003 10:08:52
Sounds like you may have a governor problem;
Is your throttle control lever an original style or aftermarket type?
Ryan
06-23-2003 10:13:54
 Re: Re: H Throttle Trouble in reply to Wayne Swenson, 06-23-2003 10:08:52
It's the original 1949 lever that came on the tractor.
