Will an SA grader blade fit on an A?
Doug in NJ
06-23-2003 09:58:39
I've got a 1946 A, with a manual front rockshaft that is spring assisted with 2 levers off to the left of the gas tank. One lever works the right side and rear rockshaft, while the other lever works the left side. I just visited a large implement place over the weekend, and they have a rusted but working snow plow/grader blade that came off the front of a Super A. They guy is telling me that with some minor welding modifications, it will fit my A. He is also saying it will be difficult to raise and lower it with the manual lift. Is he being straight with me, or am I looking at a lot of work to get it to fit? Anybody know?
Chad Penny
06-23-2003 10:31:02
 Re: Will an SA grader blade fit on an A? in reply to Doug in NJ, 06-23-2003 09:58:39
I have a super A blade on my 1940 A and it has the same levers you do mine are spring assited.
You can use that blade and yes with some minor changes in how you hook it up to the spring assist levers you can make it work fairly easy.
yes it is a lot nicer to have HYD's like on my cub and the cub blade but you do what you can.
As for lifting up and down it is easy. with the spring assist set right it is very easy to move the blade. I even saw one time where the front blade had the correct mounting for the A so it must have been made by IH. anyhow we also have a 60" mower deck for our A and use the same spring assist and it works good. I say go for if you have the ability or a friend that can help you fab up your lifting part.
just my $.02 worht!
Chad
Doug in NJ
06-23-2003 11:01:51
 Re: Re: Will an SA grader blade fit on an A? in reply to Chad Penny, 06-23-2003 10:31:02
Thanks Chad.
Do you have any pictures you can share so I can see how yours is hooked up? I'm not sure how it gets mounted or what modifications we're talking about.
