Hydraulic fluid for super A
willis
06-23-2003 17:30:47
Like to know what kind of fluid to use in the hydraulic system of Super A tractor?
Thanks
Tabor
06-25-2003 11:41:45
 Re: hydraulic fluid for super A in reply to willis, 06-23-2003 17:30:47
Use Hytran, regular engine oil is too thick and will blow the O-rings in the pump.
CNKS
06-23-2003 19:33:34
Use Hytran, engine oil is too heavy, but works fine in the H and M.
Merlin
06-23-2003 18:32:18
You will probably get as many different answers on this as there are tractors. The general consensus is, and a lot of IH dealers and mechanics will tell you, use the same oil in the hyd. unit that you use in the engine.
Dave_Id
06-23-2003 17:42:35
Case/IH Hytrans or equivalent
