300 input shaft
eric
06-23-2003 19:13:35
I recently split my 300 farmall, there seemed to be alot of oil in the clutch housing. I got a new rear engine seal and gaskets but was wondering what it would take to install new input shaft seals, that is if there are any. The tractor has a TA. Is it possible to replace these seals with out disassembling the whole trans case. Any help would be appreciated.
Aces
06-23-2003 19:33:06
 Re: 300 input shaft in reply to eric, 06-23-2003 19:13:35
Yes you can go so far as to replace the 7" TA clutch. But for the seal remove the through out bearing and remove the three cap screws that hold the sleve the through out bearing slids on the seal is in the back of the sleve.
