Cultivators for farmall M
Jon Stoffer
06-24-2003 07:10:23
I just bought a 4 row set of cultivators for my farmall M. I put them on yesterday and the left side and rear part of the cultivator will go up and stay up like they are suppost to, but the right side will go up then go back down. Does anyone know what is wrong? Please Help the corn needs cultivating
Adam R
06-24-2003 14:36:44
 Re: cultivators for farmall M in reply to Jon Stoffer, 06-24-2003 07:10:23
Does the hyd fluid leak out of the cylinder or not? If it does you probely need to make new gaskets for the cylinder (Not very hard). But if there is not a fluid leak then there is an internal leak. I would swich the cylinders around and see if the other cylinder stays up on the right side if it does then its just the cylinder and not the pump.
