Touch Control Arm Pins
SuperCmore
06-24-2003 10:50:02
Does anybody know the dimensions of the "Pins" that go in the Touch Control Arms? I've got a couple missing, and have been using bolts to operate the cultivator...think I can buy them at hardward store cheaper than Case IH...Cmore
Hugh MacKay
06-24-2003 19:57:33
 Re: Touch Control Arm Pins in reply to SuperCmore, 06-24-2003 10:50:02
C more: Haas is right and when those cheap pins bend, quite often it results in breaking the end of the rockshsft arm. You try that one on for price anywhere. I also bought a tractor where the guy had been using a hard pin but just a shade undersise. The holes in rockshaft were egg shaped from this. I have built them up twice but they don't stay. My other two tractors with proper pins are like new and one of them has seen a lot more cultivator use than the bad one.
Haas
06-24-2003 18:14:54
Be careful using substitutes. The pins are 1/2 inch diameter. don't know the length. If you get a hardware store pin, it may be soft metal and bend. Then you are stuck. I do admit the pins from IH are pricey!
