Hydraulic valve for loader on M
Jim Shannon
06-24-2003 11:07:41
Just bought a loader for my 51M. The loader has two cylinders for lift and one for dumping the bucket. I have verified my belly pump and have a good 850 psi available. I plan on running a return line through the sump drain plug once I get a decent control valve.
What control valve configuration is recommended? Any suggestions would be appreciated. My knowledge of hydraulics is limited, so keep that in mind if you respond. Thanks.
here, try this
06-24-2003 16:35:22
 Re: Hydraulic valve for loader on M in reply to Jim Shannon, 06-24-2003 11:07:41
just pick up a good two spool valve. I prfer one side to have a "float" position. I hook that side to the bucket tilt.
