Farmall H carb high speed screw adjustment
john
06-24-2003 18:53:53
I set my H at full throttle, turn in the high speed screw until it starts to run rough, then back it out??? I have been backing it out about 1/2 a turn. Thanks.
John
06-25-2003 14:53:28
 Re: Farmall H carb high speed screw adjustment in reply to john, 06-24-2003 18:53:53
Thanks!!
CNKS
06-24-2003 19:47:12
Back it out until it runs smooth, then maybe an additional one-quarter to one-half turn; you want it a little lean rather than rich. If you are pulling a heavy load with it, you can experiment with the setting that gives the most power, but you probably won't notice much difference.
