PTO Problems
Papcharlie
06-25-2003 02:58:03
My farmall international cub 1947.,,, PTO, will not stay engaged, I have it apart, but cant seem to find anything wrong... Please advise,,, Thanks Pap
Gary-Miss
06-25-2003 18:20:55
 Re: PTO Problems in reply to Papcharlie, 06-25-2003 02:58:03
As I recall fromworking on the cub Farmall. they do not have a spring loaded detent ball like most of the rest. They have a shift lever that is spring loaded and you push it down to engage or disengage it. If the slot is worn out or the slot ted plate has loosened on its one bolt (I think) and turned slightly, it won't be held in by the slotted plate. Golod ;luck.
