Clutch/Transmission prob/ ?
Chris P
06-25-2003 19:02:41
I have a 1960 Cub and it will not move on its own power. It is if it is in nutral. I can move the shift leaver and it feels and sounds like everything is moving right, but it will not engage. I can shift with or without pushing in the clutch peddel. It will role free. is this a clutch problem or someting worse??
Thanks for your help.
Alton
06-25-2003 19:41:08
 Re: Clutch/Transmission prob/ ? in reply to Chris P, 06-25-2003 19:02:41
Put in gear look through side inspection hole and let someone rock and see if shaft is moving. if it does you probally have a clutch problem. If not you probally have something wrong with transmission. Make sure the engine flywheel is not moving with the shaft.
