Another new to Farmall question
Gary_N_WV
06-26-2003 10:45:03
The kind of heart shaped instrument panel on my 1950 "C" has an ammeter to the left, switch and fuse holder in the middle and light switch to the right.
At the bottom it looks like a "knock-out" for another gauge.
What was this for?....was a temp gauge an option?
I have a couple of catalogs that list temp.gauges for the "C".
If I can put a temp gauge in,or if it's suppose to have one, where on the block or head does the sensor screw in?
DANWV
06-26-2003 20:04:15
 Re: Another new to Farmall question in reply to Gary_N_WV, 06-26-2003 10:45:03
Where are you located in WV.? I am in the eastern panhandle and I am also restoring a 1950 C. I was wondering the same thing that you had asked. I need a little help on my chargin system as the light switch makes no difference in the charging of the battery. Not quite ready to tackle that yet though
Peabody
06-26-2003 11:30:00
On my 52 Super C, that is where the temp gauge goes. The sensor screws into the side of the gooseneck fitting running from the upper radiator hose to the front of the head, above the governor.
