Steering Play
Vinnie
06-27-2003 14:14:05
Was out bushhoggin'Wed. evening and while crossing a semi rutted area, everytime the front wheels would contact a rut or windrow, it would wobble all over the place. Took the steering worm gear out an checked it. everthing looked okay. I then reassembled it and test drove it, bang, the same thing! Any pointers appreciated. I've been told to replace the sector gear and the worm gear. My tractor is a 1942 H.. Thanks and regards...
ACES
06-27-2003 15:52:29
 Re: Steering Play in reply to Vinnie, 06-27-2003 14:14:05
THE WARM AND WARM GEAR COULD NEED REPLACED, but first is the warm gear tight on the splines how about bearings and bushings if you have a full warm gear you could trun it to a better tooth when straight ahead. the bolster shaft could be warn where the bushings go some people but a shim on the left side of the top bushing between the bushing and bore to move it ti the right a little and make the gears a little tighter. It is most likely not just one thing.
