Remedy for low oil pressure...
Jesse
06-28-2003 14:14:55
I have a quick question. When I start my SC the oil presure goes up fairly nice but as I run the mower or after about 30 min, the oil pressure drops to about nothing...Should I be too concerned??? Nothing seems to be too wrong. It isn't blowing smoke...Do I need to get the head redone, or let it go....
Hugh MacKay
06-29-2003 04:23:08
 Re: Remedy for low oil pressure... in reply to Jesse, 06-28-2003 14:14:55
Jesse: Take the easy and least expensive road first. Do as Aces and JWH suggest. A very simple task, and probably 2-3 hours of nothing but time. You will have it done in lots of time to know whether you need the bearing job next winter. Doug may well be right.
JWH
06-28-2003 18:35:18
Check the aluminum oil pump cover for being warped. I think they all do it sooner or later.
Doug in OR
06-28-2003 16:12:34
This usually indicates worn bearings. You can use heavier oil or other additives, but IMHO this gives you oil starvation to the tighter places. You can run it this way, but I would plan on at least doing new bearings and possibly a crank grind this upcoming winter.
Aces
06-28-2003 15:07:19
The oil pump in the SC is about the same thing as my B the base plate is pewter and over time it will warp and then the gasket leaks so it can not pump. I have not had my B all that long and I thought the oil pressure was ok but after running it more found it was not. I just sanded the plate smooth, but have not got it back to gether yet.
