Stearing wheel on a 450
Earl in Pa
06-28-2003 18:25:28
I just bought a new stearing wheel at Red Power for my 450 with power stearing. My question is how do you remove the power stearing center cap and the old wheel. Thanks in advance.
Red Man
06-28-2003 19:08:11
 Re: Stearing wheel on a 450 in reply to Earl in Pa, 06-28-2003 18:25:28
The center cap will pry off with a screwdriver. Loosen the nut on the steering shaft under the cap with an air wrench and take off. Spray the splined shaft liberally with PB Blaster, then use the the 3 small holes around the shaft for a puller.
