1941 Farmall Steers hard
Ken
06-29-2003 13:29:46
And I mean hard. I'm building up my foremarms prety darn good from steeeering. I opened the plug in the steering gear box, and it is full of grease. The pinions and other parts seem nice nad free.
In an earlier post, someone asked about installing power steering on a Frmall A. One of the replies from a gentleman was that he uses 90W gear oil in the sterrring box. I cant find any specs/capacityies in the Farmall A service manuals I have. The steering box does use grease, correct? There is a grease ftting on it. And if the one gentleman was correct, can you safely install 90 W gear oil in the steering box?
Thanx
Ken
gene b
06-29-2003 16:01:26
 Re: 1941 Farmall Steers hard in reply to Ken, 06-29-2003 13:29:46
The grease is for the top bearing and the worm and gear run in 90wt. the output shaft and bushing need the 90wt also the bearing on the steering shaft. You mite have to tear the assy down and replace the seal and bushings also check the spindles for lube.
