Farmall 140 stalls on incline
jim burdett
06-29-2003 18:12:25
I have a farmall 140, runs great except uphill. I have replaced electricals...cap,rotor,plugs,condenser,wires,coil. runs fine on flat ground but on a hill runs for about 2 min. and then stalls. checked carb and everything looked ok and float was not stuck.
any help would be greatly appreciated
David
06-30-2003 10:07:45
 Re: farmall 140 stalls on incline in reply to jim burdett, 06-29-2003 18:12:25
Check your gas, the fuel comes out of the front of the tank. I can drive my anywhere but when the tank gets below a 1/4 tank or so I have had to back up hills or take them at an angle. Agervating little problem for a great tractor.
Hugh MacKay
06-29-2003 19:03:10
Jim: My first reaction is gas, your float may not be stuck, but may not have right level. It may need some adjustment.
The other item I have seen is, worn distributor shaft giving end play in the shaft. I had a similar problem with a Super A; rough ground, hills, a jolt, etc. it would stop. Distributor shaft was quite loose and I sent to CaseIH dealer and had it rebuilt. I understand there is no bushing when new but this is how they rebuild them. Results the tighter shaft cured my problem.
How to tell which is problem: if it sputters its gas, if it just stops probablty fire.
