HYDRAULIC LIFT ON F-12
Dan in Ore
06-29-2003 18:11:59
What oil do I use on the F-12 lift?
Thanks in advance.
Dan
F14
06-30-2003 06:53:49
 Re: HYDRAULIC LIFT ON F-12 in reply to Dan in Ore, 06-29-2003 18:11:59
I use rearend gear oil (80-90wt)in mine, as the pump drives off the transmission. If any leaks past the pump seals (and it will...) it just mixes with what's already in the rearend.
Dan in Ore
06-30-2003 08:15:39
 Re: Re: HYDRAULIC LIFT ON F-12 in reply to F14, 06-30-2003 06:53:49
Thanks 14.
