Farmall H hand crank cup
Jon Budde
06-30-2003 09:20:16
I have a 1943 H that has crank start only. The starter cup is worn out. By starter cup I mean the notched piece that meshes with the pin that runs through the front of the crank shaft. The notches are worn smooth and it is very hard to start with out the cup slipping over the pin.
Does anyone know where I can find one of these. Even a good used one off a parts tractor would be fine. The one I have has been welded on many times by the folks who had before me and it is pretty scary looking. Any help would be great. thanks. jbood1@yahoo.com
Jimmy King
07-05-2003 21:37:48
 Re: Farmall H hand crank cup in reply to Jon Budde, 06-30-2003 09:20:16
If you can find a savage yard that has savage H's or M's you should be able to get a good cup we had to crank our H some usually had to use crank to un lock the starter.
chris
07-01-2003 06:00:00
Jon
E-mail nscow@yahoo.com he can help if you have problems with address, go to e-bay they will have there.
