What gear for a parade?
Doug in NJ
06-30-2003 12:43:54
I'm gonna be riding my 46A in the July 4th parade this thursday. This will be a first. What gear and throttle speed do most of you guys use to keep a normal marching/walking pace. I haven't had the time to take her out on the road and experiment, and I don't want to screw up in the middle of the parade. Any suggestions? .... I'm thinking something like 2nd gear and low to mid throttle will do it. Thanks!
JimW
07-01-2003 08:21:31
 Re: What gear for a parade? in reply to Doug in NJ, 06-30-2003 12:43:54
Avoid clutching as much as possible. Sometimes you are better off to use a lower (not too slow) gear and use the throttle, than to continually "ride" the clutch on the tractor. Leave a little room in front of you too, makes the parade last longer for the people watching.
Jack in Fla
06-30-2003 17:17:11
Hello everybody, I parade every chance I can with my 51 J D "A", when I go, usually 3rd gear and between 1/2 to 1/4 throttle, lots of hand clutch usage, cause of the stop and go.3rd works good and you can adjust throttle as you need. I have a 25 foot Gooseneck with a dolly that I built to go under trailer so tractor can pull it, really enjoy it, would post a pic of it but don't know how, but will see if i can post it in tractor photos
Jack
moonlite
06-30-2003 17:09:29
I run my B in first. I always keep correct interval and vary speed with throttle. Sometimes wide open. We are in hilly country and usually pull a loaded wagon so use lower gear and heavy throttle for safety.
BillWV
06-30-2003 16:46:15
I was just clocking my '47 A this evening so that I'd know what gear/throttle position to run at the speed-limited antiques pulls. Used a handheld GPS, by the way. On mine, 3/4 throttle in 2nd gear is between 3 and 3-1/2 mph.
Bill
Mike ISW
06-30-2003 13:49:22
I too will be in my first parade Friday. Hard to tell what gear to go in. I'm thinking I'll start out in second and see where i need to keep throttle. If I need to stop and get into third or whatever so I can be between 1/3 and 2/3 throttle so be it. Everyone does everything for the first time sometime. Pretty philisophical,huh? Wrong spelling I know..... Good Luck and Have FUN!!!!! !!!!!
Red Dave
06-30-2003 13:06:41
Doug, it varies so much that there is no way to say what is right. There may be some parades that run at a constant speed, but I've never been in one. For instance, I ran my B in the Red Power Parade through Bloomsburg Saturday, and the speed varied from dead stop to 4th gear. That's unusual I know, and it was because of the traffic at intersections wasn't stopped completely, but you will have to just run it and see what works.
