Farmall A or Cultivision
Willy
06-30-2003 21:24:25
Can anyone tell me what I have?
I have an old Farmall, and it says "A", but then it also says Cultivision on the cowlin'
When I try to get parts from the dealer, they always ask me if I'm sure it is not a "super A "
I can't find any #'s on the tractor.
But then again, I may be looking in the wrong place. Does anyone have any info?
Hugh MacKay
07-01-2003 02:39:09
 Re: Farmall A or Cultivision in reply to Willy, 06-30-2003 21:24:25
Willy: Don't pay much attention to the word Cultivision, It was just an advertising gimick, some tractors had it and some didn't. I have even seen a few Super A with the word Cultivision.
Factory hydraulics while being quite accurate for being a Super A is not 100% either as just last week here on this site an A surfaced with factory hydraulics. It was a 1947 model and also amoung the last few built. This may well have been a hoax as the guy never did comfirm whether tracror and engine serial numbers were a match. The only accurate way to tell is by serial numbers.
If you can't find the serial numbers and the tractor has no hydraulics nor provision for them it will most certainly be an A By provision for factory hydraulics the tractor must have the top of torque tube between battery and clutch housing flat and a hole in engine block on front plate, just under distributor or mag for mounting hydraulic pump.
Vern
06-30-2003 21:40:52
Willy;
You have an "A". The "Cultivision" was put on the early As & Bs as an indicator that the operator could better see what they were cultivating. Super As have factory hydraulics.
