H idling problem
PA Steve
07-02-2003 05:46:36
I've been working on an H and can't seem to get it to idle properly. It will fire on all cylinders and has good power under load, but misses when not under load at any speed. It will even run at very slow speeds, something I wouldn't expect with such a problem. The valves have been ground and I swapped the entire carb and manifold assembly with another H to make sure the carb wasn't the problem. Both tractors ran the same way after the swap. This H has battery ignition, but as far as I can tell, everything is alright. I took the distributor apart, checked the flyweights and found no problems there. I'm at a loss for what the problem could be. Thanks for the help!
rustyfarmall
07-02-2003 06:40:58
 Re: H idling problem in reply to PA Steve, 07-02-2003 05:46:36
The problem is more than likely still in the distributor, check for excess play in the shaft, you may need new bushings, also check for excess play in the rotation, the drive gears may be worn.
