Farmall H throttle notches, do you oil them?
john
07-02-2003 19:18:07
I have the origional throttle on my H, I was wondering if I should oil, grease or just leave the notches alone?
SuperHank
07-03-2003 08:52:29
 Re: Farmall H throttle notches, do you oil them? in reply to john, 07-02-2003 19:18:07
Get to Tractor Supply as quick as you can and get a friction throttle lever. Save the old one for future restoration etc. Best move you can make
CNKS
07-03-2003 18:24:08
 Re: Re: Farmall H throttle notches, do you oil t in reply to SuperHank, 07-03-2003 08:52:29
The newer OEM style have notches instead of saw teeth, works much better, and looks much better, in my opinion, than the friction control--I have both on my tractors.
Wayne Swenson
07-03-2003 08:29:34
A dab of oil or grease on the lever OPPOSITE THE NOTCHES will help it slide smoothly.
Nothing on the notch area itself, please.
Miss Grundy
07-03-2003 03:34:52
If you use a heavy black grease your laundry woman will love you.
CNKS
07-02-2003 19:20:23
Leave them alone! As they wear, you will have enough trouble keeping the notch in the grooves without oil.
