Farmall 400 gas wont start nor run!
justin from mcd
07-02-2003 19:58:48
im currently working on a mans tractor and it doesnt want to start he redid the electriacal system toatoly and carb looks rebbuilt he let it sit for a year then put all this new stuff on it and it didnt start after he let it sit nor now after puttin the new parts on any help would be appreciated were there common problems for a 400 that sit and any hints on the tractor itself TIA .
Ben in KY
07-02-2003 20:18:17
 Re: farmall 400 gas wont start nor run! in reply to justin from mcdonough, 07-02-2003 19:58:48
Here are a few things to check to help us troubleshoot your problem.
1. does it crank over ?
2. Does it have compression ?
3. does it get spark ?
4. Are the spark plug wires on in the correct order and timing.
5. Does it get gas into the cylinders ? ie wet spark plugs.
One common problem of gasdoline engines that sit for a year or more is for the carburator to get gummed up and need cleaning.
Michael Soldan
07-02-2003 20:14:51
Justin, you didn't give us a lot of detail..is the tractor not getting spark to the plugs or is it fuel related?..pull a plug wire and hold it out from the plug while someone cranks the engine, if you have spark I would remove the air tube to the carb and using a misting bottle spray some gasoline into the carb as the engine turns over..if the tractor tries it may be carb /fuel related..if you have both spark and fuel check on timing..inform us as you go and there will be more help pop up on this line....Mike in Exeter Ontario
