Farmall A story
Terry
07-02-2003 21:04:36
Through a friend I found out about this Farmall A.
It hadn't been run for a few years and was sitting in the back of this guys yard with black plastic over it. Talk about stinky gas, wow. That black plastic didn't help that situation a bit.
Anyhow, I thought about buying it, but I already have enough tractors, so I told my friend about it and convinced him to go and look at it with me.
It turns out that it is a 1950 super A and it was originally painted white. He really got excited and paid $1100 for it, which is ok, if he doesn't find much wrong with it. He hopes to have it running tomorrow.
He is very knowledgeable about mechanical stuff, so the tractor found a good home.
He is thinking about painting the tractor white again. What color would you guys paint it?? Can a person find the correct decals for a white A??
CNKS
07-03-2003 18:53:35
 Re: Farmall A story in reply to Terry, 07-02-2003 21:04:36
Check the serial number, should be from 281269-285298.
Hugh MacKay
07-03-2003 14:07:49
Terry: I would paint it white. Decals shouldn't be a problem, they just reverse the colors. Probably you will find not every supplier has them, but the good ones will.
CNKS
07-03-2003 19:01:21
 Re: Re: Farmall A story in reply to Hugh MacKay, 07-03-2003 14:07:49
OEM decals were not reversed, they were the same as the ones on the red tractors, except that I believe you have to paint the I in IH red on the ones you buy now. Some manufactures make decals with a red background, would make them stand out on a white tractor, but they are not correct. I do think if IH would have used different decals, the tractors would look better.
