Order Farmall Cub Parts Online
Cub not running when warm/under load
Scott B
07-03-2003 09:30:43
We have a cub that has been running for the last 2 years with no problems. This year it has stopped running. We have replaced the plugs, points, checked timing, and tested a working coil on it. It starts fine and will run when cool, but 2 or 3 minutes after starting it if we try and put it in gear it stalls when taking off. Cut the gas all the way back and it will start up fine, try to move and it stalls. Any thoughts?
Gordon
07-03-2003 22:38:20
 Re: Cub not running when warm/under load in reply to Scott B, 07-03-2003 09:30:43
check your air cleaner, it may be clogged in the mesh, wash it from the carburator port
George Willer
07-03-2003 10:04:50
Scott,
You are victim of the very common fuel flow problem. There are several places to look for trouble, but start with the plug on the bottom of the carburetor and work toward the tank. Run at least a 1/2 pint from the plug to be sure you aren't just draining the bowl. You should get a full, steady flow.
George Willer
