Regulator for 12volt gen?
Andy
07-04-2003 00:44:16
My Napa guy is stumped? Stock 6 volt gen has been converted to a 12 volt. Anyone have a Napa part number for the correct regulator??
Did I mention it's for a B?
Jumping my way home.
Farmall450man
07-07-2003 05:59:14
 Re: Regulator for 12volt gen? in reply to Andy, 07-04-2003 00:44:16
Andy, there is a 12 volt regulator on eBay for $31. I believe it is for a negitive ground, as it is listed as being for the 460 & 560.
Andy
07-07-2003 13:09:50
 Re: Re: Regulator for 12volt gen? in reply to Farmall450man, 07-07-2003 05:59:14
Thanks Farmall450man!!!
Can't seem to find the thread.... don't suppose you know where it's listed on ebay?
31, 32, 33.....
Doug in OR
07-04-2003 09:03:20
I suppose you can get a regulator that comes close, but in the end you will need to adjust the regulator. This is NOT an easy thing to do. Good luck.
This is why I would recomend an alternator for any 12 volt conversion. No adjustment needed when you are finished.
Andy
07-05-2003 09:21:06
 Re: Re: Regulator for 12volt gen? in reply to Doug in OR, 07-04-2003 09:03:20
Understood Doug,
Already bought the gen - impulse buy. Plus, I wanted to try and keep an original look if you know what I mean. I'll pickup the stock 6v regulator and beg for advice to adjust it.
Andy
Doug in OR
07-06-2003 09:17:06
 Re: Re: Re: Regulator for 12volt gen? in reply to Andy, 07-05-2003 09:21:06
I suggest that you pick up a stock 12 volt regulator, and try to adjust that. It might even come close enough to working as-is. All I'm saying is, adjusting a regulator is VERY time-consuming.
gene b
07-04-2003 03:55:12
You need the DELCO-REMY NUMBER OFF YOUR GEN. There is no way to change regulators from 6v to 12 you should be 6v pos ground on the gen if it is original. Dont know what you are trying to do with tractor restore or just want it to charge it makes a lot of difference to how you aproach the problem. Much better staying with original set-up is cheaper than all the changes. Use 1ga cables for the ground and to the starter sw for best results.
Andy
07-05-2003 09:18:12
 Re: Re: Regulator for 12volt gen? in reply to gene b, 07-04-2003 03:55:12
Thanks Gene,
Yes - I want a charging system... for lights. The gen I have is orig but upgraded to a 12 volt system. Wasn't sure if a regulator designed for a 6v would work with the extra voltage?
Andy
