Ih 240 grinds update
dean
07-04-2003 05:24:26
i split my tractor apart for 3rd time cause gears still grind brought clutch, pressure, flywheel to ih expert; he says clutch facing was a little too wide in diameter, and to grind edge off to steel. Has this ever happened to anyone?
K.B.
07-04-2003 17:31:52
 Re: ih 240 grinds update in reply to dean, 07-04-2003 05:24:26
I agree, you shouldn't have to be grinding on a brand new clutch. Where did you get it? Definetly sounds like you found the problem, though.
Hugh MacKay
07-04-2003 13:04:48
dean: I think I would be taking that clutch back to from where it came. That is rediculous, making modifications to new parts.
