Industrial 340
Rick
07-04-2003 07:45:19
I am having trouble with my hydraulics on my tractor, the MCV on the hydraulics seems to be sticking when I run my 3 point lift or loader , it works fine until the tractor warms up . It will load the tractor down on rpm's until I give the load up on the bucket a quick tap up and it seems to release whatever is stuck , any answers. I have disassembled the mcv everything except taking out the pressure control spring and ball assembly. It seemed to do it less often but still when it gets warmed up it does it .
F20II
07-04-2003 09:54:22
 Re: Industrial 340 in reply to Rick, 07-04-2003 07:45:19
Have you changed the hyd filters on each side of the trans. They can still be bought from case/IH an that may make the difference. I had somewhat of the same problem in my 340D rowcrop, changed them out an it went away. The old one's I took out looked like they had been in there since the tractor was new in 1961.
