I need help
Mike 706
07-06-2003 16:14:54
Next week i am gonna go to a tractor pull and it allows u 10% over stock hp. i am using my 706 which is rated at 74 and i can go to 84 according to the group doing the pull. what can i do to get 10 more hp that would be cheap and easy for someone without alot of experience to do. also and tips on what gear and when to use the T/A would be nice too. I have pulled it once before but its so addicting that i wanna get the most outta that tractor. thanks for any advice
mike706
Larry B
07-06-2003 18:00:42
 Re: I need help in reply to Mike 706, 07-06-2003 16:14:54
Is this 706 gas or diesel?
George Willer
07-06-2003 16:41:41
Your club may be different, but ours allows 10% over *RPM*, not horsepower. Increasing rpm by 10% would yield significantly more than 10% HP increase, assuming the engine can maintain rpm. It can be done by simply advancing the governor max rpm limit setting.
Your group needs to brush up on the math! 74 + 10% = 81.4. :-)
All our pulls must be done in first or second gear, and the TA *must* not be shifted to low.
Naturally, everyone wants to be the winner! I always try to...but usually, it doesn't work.
George Willer
Mike706
07-06-2003 20:16:06
 Re: Re: I need help in reply to George Willer, 07-06-2003 16:41:41
sorry about that it might be to hp all i know is i can go from 74 to 84 so its pry hp. It is a gas tractor and u can run any gear any time
