Order Farmall Cub Parts Online
Cub Serial Number Location
Mike in La.
07-06-2003 16:35:29
Going to look a Cub for sale tomorrow. Where can I find the serial number. It was advertised as an "early model" if that makes a difference. As always thanks for any help.
EZ
07-06-2003 18:50:02
 Re: Cub Serial Number Location in reply to Mike in La., 07-06-2003 16:35:29
Mike,
Look for the tag near the front of the tractor, you can follow the steering rod right down to the tag. If no tag:
Look on the engine block for a stamped number just under the valve cover. It is on the side where you fill the crankcase on a flat machined surface. Good luck.
