Another Water Leak Question
Kevin
07-07-2003 07:57:02
I have a small leak that looks like it is coming from around the radiator fan on an M. Is the water pump behind the fan? Can I add that yellow powder or pellets into the radiator that is supposed to stop leaks without doing damage to any other parts? Or is there another solution? Thanks.
Hermit
07-07-2003 18:49:16
 Re: Another Water Leak Question in reply to Kevin, 07-07-2003 07:57:02
If the leak is coming from the front side of the fan, it could be the packing nut around the water pump shaft needs to be tightened.
rustyfarmall
07-07-2003 09:49:42
I have my doubts as to whether or not the stop leak stuff will be effective for a water pump leak, If the tractor were mine I think I would get a rebuild kit and have at it.
Fix it right the first time and you won't have to worry about it again.
Randy in NE
07-07-2003 08:05:13
The water pump is behind the fan and is driven by the fan belt. There are re-build kits available from your Case/IH dealer. Everybody has their own opinions on the use of a stop-leak product. I am not a fan of them. Just my $0.02 worth.
