MD How to adjust rpm?
Joe
07-07-2003 13:27:28
I was just wondering if there was a way to make my MD open up more it don't seem to have enough rpm's at full throtle any help would be appreciated
Jarrod
07-08-2003 18:36:06
 Re: MD How to adjust rpm? in reply to Joe, 07-07-2003 13:27:28
there is a stop screw inside the pump. easy to do if you must/want. If all else fails let me know.
Roger
07-07-2003 19:36:05
Joe, The first thing to do is to adjust the throttle linkage on the arm on the side of the injector pump. There is a procedure in the manual for doing it to get the correct rpm. There is also an adjustment on the main throttle linkage. If you make adjustments to the linkage you need to make sure you can still move the throttle lever far enough to shut off the engine in the other end of the travel. If that doesn't do it then it is inside the injector pump and I have not had any experience with that. Roger
