SMTA hydraulic problems, need help...
Terry
07-07-2003 19:04:37
My SMTA had problems lifting a haybine and other equipment. I put a hydraulic gauge tester on it and it tested out at about 500psi. I put another hydraulic pump (used) on it and now it shows about 2200psi.
Here's the problem: When I test it when I first start it, it shows 2200psi. After about 3 minutes it drops down to about 1000psi. The Char-Lynn power steering doesn't seem to work properly. It does work but it feels choppy and harder to turn then it should. (The hydraulic oil is full) I have some pictures at www.sonnentag.com that shows how the hydraulics lines are connected. Do I have some lines screwed up or what? Please let me know any ideas that may be the problem. Thanks.
lindy
07-10-2003 07:06:26
 Re: SMTA hydraulic problems, need help... in reply to Terry, 07-07-2003 19:04:37
2200 psi sounds exceptionally high. What pump did you put on it? I assume you replaced the original located between the distributer drive and distributer?
Not only that, but a 1000 psi is pretty close to all it ever did. what doest the pressure do when you try to lift the haybine?
someplace there's a flow divider, which is there to make sure the steering always gets enough to operate. Have you adjusted it? If it's not set correctly, it'll starve your steering, and imitate a low hyd. fluid symptom.
Is everything else stock? I think there can be some wear inside the hydraulic control that will screw stuff up, too, and I don't know what to think about that.
I have a SMTA, and although it's an old, pretty wimpy system, it would still life a haybine easily, which isn't that hard.
Terry
07-10-2003 08:39:26
 Re: Re: SMTA hydraulic problems, need help... in reply to lindy, 07-10-2003 07:06:26
How do you adjust the flow divider?
