SMTA Hydraulic help needed.....
Terry
07-08-2003 08:58:59
My SMTA had problems lifting a haybine and other equipment. I put a hydraulic gauge tester on it and it tested out at about 500psi. I put another hydraulic pump (used) on it and now it shows about 2200psi.
Here's the problem: When I test it when I first start it, it shows 2200psi. After about 3 minutes it drops down to about 1000psi. The Char-Lynn power steering doesn't seem to work properly. It does work but it feels choppy and harder to turn then it should. (The hydraulic oil is full) I have some pictures at www.sonnentag.com that shows how the hydraulics lines are connected. Do I have some lines screwed up or what? Please let me know any ideas that may be the problem. Thanks.
Dan
07-08-2003 21:46:49
 Re: SMTA Hydraulic help needed..... in reply to Terry, 07-08-2003 08:58:59
I have a SMTA with the remote valve also but no power steering. From your pictures it looks like your pressure line goes from the pump, through the priority valve then into the left side of teh lift all box. on my SMTA the pressure line goes into the right side of the lift all box. You have to have the handle locked back on the lift all valve to work the remote or the otherway around if using the lift all. It seems like your pressure line is hooked into an outlet of the lift all. You might try running the pressure hose to the top fitting on the right and see if it helps.
