Antifreeze in the oil
dave w
07-08-2003 18:50:17
Changed oil couple of days ago and the oil was milky. I looked at it today and antifreeze was in the bottom of the oil pan. It does not have white smoke. What could have happened? Could it be a head gasket or worse? How to I diagnose the reason?
thanks for your responses.
dw
Will Sick
07-09-2003 20:44:13
 Re: antifreeze in the oil in reply to dave w, 07-08-2003 18:50:17
Take the pan off and place a piece of cardboard under the motor and let it set overnight. Then you can see where the anti-freeze is comin from.
mike in mn
07-09-2003 15:59:20
I would have the head checked for cracks. If it has any have them fixed.also check your head gasket for blow outs. something else that you might want to have checked are your sleeves. One of them might have a crack or two in it. But you cant see them. the sleeves will have to be sandblasted on the back side then looked at through a magnafying glass to see the cracks. the early case tractors are known for cracking the sleeves. and I only know of a couple oliver tractors doing this.
bcPA
07-09-2003 13:36:26
pull head magnaflux head do valve job with new valves for unleaded gas if the tractor is a keeper put together with a new head gasket GOOD LUCK
Mike ISW
07-09-2003 02:43:54
What make and model tractor?
dave
07-09-2003 10:36:44
 Re: Re: antifreeze in the oil in reply to Mike ISW, 07-09-2003 02:43:54
Sorry, forgot to mention is is a M farmall
thanks
LOU
07-09-2003 12:42:10
 Re: Re: Re: antifreeze in the oil in reply to dave, 07-09-2003 10:36:44
Mike, My H did it right after the rebuild. My solution was to retorque the head. Solved the problem so far (crossed fingers), but I think it would have to be done before the head gasket gets dried out. Good Luck
