Casting numbers on model A
Michael
07-09-2003 17:13:09
I have an Model A with a Cracked engine the casting number is 6342-DH will any A,B eng fit in it place. Is there any that will not fit
Thanks guy for all you help Michael
CNKS
07-09-2003 19:05:09
 Re: casting numbers on model A in reply to Michael, 07-09-2003 17:13:09
As long as it is a C113 it will fit without modification -- except -- the Super A and C had hydraulics, you will have to fabricate a plate to cover the opening for the hydraulic pump. The C123 engine used in the Super C--up, and the Super A1--up, is physically the same size, it has a larger bore, and was meant to be used with a water pump and a larger radiator, but it will bolt up to your existing radiator. Sheet metal won't fit if you use a C123 radiator.
