1948 M No Start
Jimmy T.
07-10-2003 08:51:06
I have a 48' M with no spark. I replaced the points, condenser,& coil in the mag. It seems to have a short grounding out the ingition. I checked the kill switch and it is working fine.But I am still getting a short to frame at the ignition. Any help or ideas? thanks, Jim.
49 Cubber!
07-10-2003 13:04:46
 Re: 1948 M No Start in reply to Jimmy T., 07-10-2003 08:51:06
Have you tried to start it with the wire off? Also may want to check where the wire screws on to the mag for a bad spot.
DE M Man
07-10-2003 15:53:14
 Re: Re: 1948 M No Start in reply to 49 Cubber!, 07-10-2003 13:04:46
Sometimes it is something simpler than we look for. We get involved in a bigger process than we need to. I have been working on my 1952 M for over a month in my spare time with the same type of problem. I just got it started two days ago. I ended up with a corroded contact. I took each electrical contact off one by one. I then sanded each contact point and wire connector to a bright surface and used dielectric grease on each connection. (I bought the dielectric grease in the electrical department at a home improvement store. It costs less and comes in a larger quantity than from the auto store.) I turned over the tractor and TADA.
Good Luck
DE M Man
JIMMY T
07-11-2003 10:50:07
 Re: Re: Re: 1948 M No Start in reply to DE M Man, 07-10-2003 15:53:14
I HAVE REMOVED THE WIRE TO THE MAG, BUT EVEN WITH IT REMOVED I IS STILL SHOWING A SHORT TO GROUND AT THE WIRE TERMINAL. I DONT KNOW WHAT ELSE COULD CAUSE THIS TYPE OF SHORT IN THE MAG. I DID CHECK MOST OF THE WIRING FOR SHORTS AND FOUND BARE SPOTS TO FRAME AND REPAIRED THEM. THE ONLY WAY I HAVE FOUND TO REMOVE THE SHORT IN TO TAKE OUT THE COIL, BUT IF THE COIL IS IN THE MAG. I STILL SHOW A SHORT TO THE TERMINAL (WITH THE POINTS OPEN).EVEN WITH ALL THE EXTERNAL WIRING REMOVED IT SHOULD FIRE THE MAG. RIGHT? (AS IF YOU WERE HAND STARTING )
