560 Gas wont start after new tune up HELP PLEASE
big red 1
07-10-2003 17:42:38
ok the tractor set for a while,I got it home and got it running so I thinking new cap points rotor condenser,plugs,wires now I cant get it to start fuel going to the carb everything ran fine on the old plugwires old cap and points rotor,points and new plugs,distributer wasnt moved ,firing order is correct 153624 now she wont start condenser was replaced as well HELP boys what in the $%*^ is going on or not as always thanks in advance
rustyfarmall
07-11-2003 05:46:23
 Re: 560 Gas wont start after new tune up HELP PLEA in reply to big red 1, 07-10-2003 17:42:38
Check the connection inside the distributor where the wire from the points and the condensor connect, make sure that the ends of the wires are not touching the dist. housing.
Randy in NE
07-11-2003 05:29:37
Did you get #1 wire back to the right place on the distributor cap? Easy to check by getting #1 to TDC of the compression stroke and checking the postion of the rotor.
Dave_Id
07-10-2003 18:21:14
Perhaps the condensor you installed is bad from the factory.. I'm not trying to be a smartallec, but you did put the rotor back on, right? (I forgot to do that a couple of times.). Also, did you install graphite core wires instead of copper core? Recheck the point gap too. These are just a few suggestions to start with.
